> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/developing-with-ndi/advanced-sdk/using-h.264-h.265-and-aac-codecs/h.264-support.md).
# H.264 Support
The H.264 parameter sets must be provided for every I-frame. For H.264, these are the SPS and PPS NAL units. They must be in Annex B format, along with their start codes. Provide them in both of the following places:
* Inline in the main bitstream (the data\_size bytes), immediately before the first slice of the I-frame.
* In the extra data (the extra\_data\_size bytes that follow the main bitstream).
Both copies must be identical and must come from the same encoder output. Set extra\_data\_size to 0 for frames that are not I-frames.
Some decoders, including the hardware decoders used on Windows, only read the parameter sets from the main bitstream. Other decoders, and receivers that record or pass through the compressed stream, use the extra data. Providing both makes sure that your stream can be decoded by all receivers.
GET https://docs.ndi.video/all/developing-with-ndi/advanced-sdk/using-h.264-h.265-and-aac-codecs/h.264-support.md?ask=<question>&goal=<user_goal>
