> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/developing-with-ndi/advanced-sdk/ndi-sdk-review/video-formats.md). Agents can also search and read this documentation through its [MCP server](https://docs.ndi.video/all/~gitbook/mcp).
# Video Formats
Decoding is more complex than encoding, because you do not get to specify what format you are sent. It is recommended that you support as many possible video formats as you wish, although if this is not possible (e.g., non-video resolutions) you can either scale, or simply provide a place-holder image. It is important that you support the three possible video formats (4:2:0, 4:2:2, 4:2:2:4) since these are in common use. If you cannot process the alpha channel, it is recommended that you multiply the image against black.
It is also important to understand that it is the NDI sender that determines the video and audio clock rates. A simple framebuffer is not sufficient to smoothly display audio and video without glitches.
GET https://docs.ndi.video/all/developing-with-ndi/advanced-sdk/ndi-sdk-review/video-formats.md?ask=<question>&goal=<user_goal>
