> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/using-ndi/ndi-for-audio/audio-over-ip.md). Agents can also search and read this documentation through its [MCP server](https://docs.ndi.video/all/~gitbook/mcp).
# Audio Over IP
**Audio over IP** refers to the transmission of digital audio across [IP networks](#user-content-fn-1)[^1]. This technology enables high-quality audio streams to be sent between devices and locations with minimal latency. AoIP can be used for broadcasting, live sound reinforcement, recording studios, and more.
## Key concepts
### **Codec**
To efficiently transmit audio over IP, the digital audio data is often compressed using a codec (compressor-decompressor). Codecs like AAC, MP3, and Opus are designed to reduce the amount of data needed to represent the audio without significantly compromising quality.
### **Packetization**
Digital audio is divided into packets, small chunks of data that are transmitted over the network. Each packet contains a portion of the audio signal and metadata for routing and reassembling the audio on the receiving end.
### **Protocols**
Several protocols are used to manage the transmission of audio over IP. These include [**RTP**](#user-content-fn-2)[^2] for streaming audio, [**SIP**](#user-content-fn-3)[^3] for signaling and controlling communications sessions, and more specialized protocols like Dante, AES67, and Ravenna, each designed for specific use cases and industries.
## Synchronization
Synchronization is a critical aspect of Audio over IP systems, ensuring that audio packets from various sources arrive in time and are played back coherently. Synchronization may refer to clock synchronization between endpoints (i.e. the same function as word clock in digital audio), or between channels in a stream. Achieving precise synchronization across a network involves several key mechanisms:
### **Precision Time Protocol (PTP)**
For environments requiring higher precision than NTP, PTP (defined in IEEE 1588) provides sub-microsecond accuracy, making it ideal for professional audio and video applications. Protocols like AES67 and Dante use PTP for clock synchronization between endpoints.
### **Sample Accurate Synchronization**
In professional audio environments, it's essential that audio samples are aligned perfectly across multiple streams or channels. This can be achieved through sample-accurate timing information embedded in the audio packets or external clocking mechanisms provided by the AoIP protocol.
### **Jitter Buffers**
To cope with timing variations (jitter) in packet arrival caused by network congestion or path variations, AoIP devices use jitter buffers. These temporarily store incoming packets to realign them into a steady stream before playback, ensuring smooth audio delivery.
[^1]: An IP (Internet Protocol) network is a computer network that uses IP, a set of rules defining how data is sent and received over the internet, to facilitate communication among interconnected devices.
[^2]: The Real-time Transport Protocol (RTP) is a [network protocol](https://en.wikipedia.org/wiki/Network_protocol) for delivering audio and video over [IP networks](https://en.wikipedia.org/wiki/IP_networks). RTP is used in communication and entertainment systems that involve [streaming media](https://en.wikipedia.org/wiki/Streaming_media), such as [telephony](https://en.wikipedia.org/wiki/Telephony), [video teleconference](https://en.wikipedia.org/wiki/Video_teleconference) applications including [WebRTC](https://en.wikipedia.org/wiki/WebRTC), [television services](https://en.wikipedia.org/wiki/IPTV) and web-based [push-to-talk](https://en.wikipedia.org/wiki/Push-to-talk) features.
[^3]: The Session Initiation Protocol (SIP) is a [signaling protocol](https://en.wikipedia.org/wiki/Signaling_protocol) used for initiating, maintaining, and terminating [communication sessions](https://en.wikipedia.org/wiki/Communication_session) that include voice, video and messaging applications.[\[1\]](https://en.wikipedia.org/wiki/Session_Initiation_Protocol#cite_note-What_is_SIP?-1) SIP is used in [Internet telephony](https://en.wikipedia.org/wiki/Internet_telephony), in private IP telephone systems, as well as mobile phone calling over [LTE](https://en.wikipedia.org/wiki/LTE_\(telecommunication\)) ([VoLTE](https://en.wikipedia.org/wiki/VoLTE)).
GET https://docs.ndi.video/all/using-ndi/ndi-for-audio/audio-over-ip.md?ask=<question>&goal=<user_goal>
