> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-for-mac/discovery/launch-discovery-server-using-command-line-for-macos.md).
# Launch Discovery Server using Command Line for MacOS
## On Mac
1. You will first need to insure that you have installed the [NDI SDK](https://docs.ndi.video/all/developing-with-ndi/sdk.md). By default it will install to Library
2. If you did not change the install location, open [Terminal ](https://support.apple.com/guide/terminal/welcome/mac)on MacOS and enter the following command:&#x20;
open -a "Terminal" "/Library/NDI SDK for Apple/bin/Application.Mac.NDI.DirectoryService"
3. A separate Terminal window will open with NDI Discovery Service running. If a different directory was chosen to install the NDI SDK to, replace 'Library' with your chosen directory path.
<figure><img src="https://3444609009-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FDO9LSaUxLOBIgPjyrjR1%2Fuploads%2F8HPw1YE61l1KAIsNUU9f%2Fimage.png?alt=media&amp;token=71895459-024a-4cc1-a67c-a849e6bc1848" alt=""><figcaption></figcaption></figure>
3. On the NDI Sender, open [Access Manager](https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-for-windows/access-manager.md), and enter the IP address of your Mac and the **Port Number**
If you choose not to use Access Manager you can still enter the IP address using the settings in the relevant section of the NDI device
GET https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-for-mac/discovery/launch-discovery-server-using-command-line-for-macos.md?ask=<question>&goal=<user_goal>
