> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/developing-with-ndi/advanced-sdk/av-sync/creating-and-destroying-devices.md).
# Creating and Destroying Devices
### Creating and destroying devices
It is very simple to create and destroy a device. Simply create an NDI receiver that one wishes to receive audio from and pass it into `NDIlib_avsync_create`, this will return an instance of type `NDIlib_avsync_instance_t` which may be used until you no longer need it. Once you no longer need it you should call `NDIlib_avsync_destroy`. Please note that you should destroy a device before the corresponding `NDIlib_recv_instance_t` is called since an internal reference to this object is kept within the `NDIlib_avsync_instance_t`.
GET https://docs.ndi.video/all/developing-with-ndi/advanced-sdk/av-sync/creating-and-destroying-devices.md?ask=<question>&goal=<user_goal>
