Prebuilt uSD Images
This page details how to obtain and use prebuilt Micro SD card images with supported FPGA development boards to easily create a working NDI encoder or decoder.
Login Details
Default username: debian
Default password: temppwd
sudo is enabled without password for root access
root login is disabled
Obtaining the uSD Image Files
The uSD images may be downloaded via the following URLs:
Manufacturer
Board
uSD Image Download URL
Altera
A10-SoCDK
http://ndi.link/NDIUSDA10
Digilent
Zybo-Z7-20
http://ndi.link/NDIUSDZYBO
Digilent
Arty-Z7-20
Xilinx
ZCU104
http://ndi.link/NDIUSDZCU
Xilinx
Kria KV260
http://ndi.link/NDIUSDKV260
NOTE: The same uSD image is used for the Zybo-Z7-20 board, and the Arty-Z7-20. The uSD image contains boot files for both systems. To use the image with the Arty-Z7-20, you must update the boot files on the FAT partition prior to booting on the Arty development board.
Each uSD image is a zip archive of three files:
Extension
Description
.img.xz
The image file (xz compressed)
.bmap
A block map file for use with bmaptools (highly recommended)
.md5
Checksum of the above two files
Most users will likely only need to use the img.xz file.
Writing the Image to a uSD Card
Use of bmaptool at a Linux command line is the most efficient way to write the image file to a uSD card. If this is not an option or is considered too complex, any uSD imaging tool which supports xz compression can be used. Etcherarrow-up-right is a good choice if you do not already have a preference.
Using the Image
Insert the programmed uSD card into the development board and boot as usual. It is recommended you connect to the serial terminal (via USB). All images use the following console settings:
The system will boot and display the IP address, as well as the default username and password at the serial console login prompt. You may login either via the serial console or remotely via ssh.
First Boot
The initial boot will take somewhat longer than normal as a new set of ssh keys are generated and the root partition is expanded to fill the uSD card.
Running the Example NDI Encode Application
An example NDI source application is provided. This application is launched automatically at boot and may also be run from the command line. The utility is named ndi_encode and is capable of using a generated video pattern or live HDMI input as the video source. The application includes various command-line options to control the initial video mode as well as a command interpreter that can be used to change the operating mode at run-time. To launch the demo from the command line, simply run one of the following commands:
Once running, the operating mode can be changed by typing commands at the console. Type "help" to get a list of commands.
If running with HDMI input on the ZCU104, the second virtual serial port is used as a console for the Cortex-R5 running the HDMI monitoring software. Connection details are the same as the Linux console:
The R5 will report changes in the incoming HDMI stream on this port.
Known Issues and Limitations
While the NDI Encoder core is fully functional the example software and demo platforms currently have some limitations:
  • This version of the NDI Advanced SDK is designed for development use and will run on a stream for 30 minutes. For a commercial use license, please email [email protected]
  • Due to the asynchronous nature of the startup scripts, the system clock may be adjusted after the ndi_encode example is launched. If this happens, it may trigger the 30 minute timeout even though the application may not have been running for 30 minutes of "wall clock" time. Kill and re-start the demo application to resume NDI streaming.
  • The HDMI input hardware for the ZCU104 uses an evaluation license, so HDMI video will stop being received and the image will turn "green" after apx. 1 hour of operation. Reprogram the FPGA (eg: reboot) to restore normal operation.
  • While HDMI input on the ZCU104 is functional, the HDMI management software (running on one of the R5 cores) does not communicate with the ndi_encode application. The video format tracking hardware is used to detect video format changes, however more details regarding the HDMI signal are available via the HDMI management software.
Running the Example NDI Decode Application
An example NDI receive application is provided. This application is launched manually by executing ndi_decode. When launched with no options the utility will attempt to locate NDI sources on the local network and will automatically connect to the first source found. A specific NDI source may be specified using the -s parameter:
NOTE: The default boot files on the uSD image must be switched to the NDI Decode version prior to running the ndi_decode application. See the "Available Examples" section for your specific board for details.
Known issues and limitations
  • "Scaling" is performed by manipulating line stride when the NDI stream and video output resolutions do not match
  • Format conversion is not performed between 4:2:2 and 4:2:0 video sources. If the output video format does not match the NDI stream format, a warning is displayed on the Linux console.
Board Details
Connections and settings required to boot using the uSD images. Refer to the vendor documentation for full details.
Altera Arria-10 SoC Development Kit
Available Examples
Two FPGA examples are available for the ZCU104 board:
  • Decode example with 4 NDI Decode cores
  • Encode example with 4 NDI Encode cores
The default uSD image uses the Enc files, however files for all examples are included on the uSD card. To change the example design, simply update the FPGA programming files in the /boot directory and cycle power:
Jumpers and Switches
All jumpers and switches are set per the defaults listed in section 3 of the Arria 10 SoC Development Kit User Guide.
Ref
Function
Setting
SW1
Boot Mode
All off
SW2
User Switches
All off
SW3.1
A10 JTAG
Off
SW3.2
Max V JTAG
Off
SW3.3
FMCA JTAG
On
SW3.4
FMCB JTAG
On
SW3.5
PCIe JTAG
On
SW3.6
MSTR0 JTAG
Off
SW3.7
MSTR1 JTAG
Off
SW3.8
MSTR2 JTAG
Off
SW4
MSEL
All off
J16
OSC2 Clk Sel
Short
J17
OSC2 Clk Sel
Short
J30
HPS Core Voltage
Short
J32
FMCBVADJ
Short 9 and 10
J42
FMCAVADJ
Short 9 and 10
J3
BSEL0
Short left 2 pins
J4
BSEL1
Short upper 2 pins
J5
BSEL2
Short upper 2 pins
Connections
Ref
Function / Label
Connect to
J19
FMC Port B
Bitec FMC HDMI Daughter Card Rev. 11
J5
HPS Ethernet
Local Ethernet network
J10
PROG/UART
Host system USB port
J36
Power
Power Supply Module
RX
Bitec HDMI Rx
HDMI video source (NDI Encode)
TX
Bitec HDMI Tx
HDMI video output (NDI Decode)
LEDs
LED
Function
FPGA_LED0
Tally (Main or Preview)
FPGA_LED1
Tally (Main)
FPGA_LED2
Tally (Preview)
FPGA_LED3
CPU load
Digilent Zybo-Z7-20
Available Examples
Three FPGA examples are available for the Zybo-Z7 board:
  • Decode.Xil: 4-core NDI Decoder with 1 GB of 32-bit SDRAM
  • Encode.Xil: 4-core NDI Encoder with 1 GB of 32-bit SDRAM
  • Enc-Lite.Xil: 2-core NDI Encoder with 512 MB of 16-bit SDRAM (1 SDRAM chip is unused)
The default uSD image uses the 4-core Encoder files, however files for all three examples are included on the uSD card. To change the example design, simply update the files in the /boot directory and reboot:
The "Enc-Lite" Encode example is intended to allow performance evaluation of a typical "minimal" Zynq platform that uses only a single SDRAM memory chip with a 16-bit memory bus. This design is still capable of processing 1080p60 video.
The "Full" Encode example will have lower latency at all resolutions and can in theory compress up to 4Kp60 4:2:0 video (with enough available SDRAM bandwidth). A source of 4K video would also be required (eg: Analog Devices ADV7619, ITE IT68059) since the HDMI I/O on the Zybo-Z7 does not support resolutions beyond 1080p60.
Ref
Function
Setting
JP5
Boot Mode
SD
JP6
Power
WALL
Connections
Ref
Function / Label
Connect to
J9
HDMI Rx
J8
HDMI Tx
J7
Line In
Analog audio in
J5
Headphone
Analog audio out
J3
Ethernet
J17
Power
Appropriate 5V power supply
J12
PROG/UART
LEDs
LED
Function
LD0
Tally (Main)
LD1
Tally (Preview)
LD2
CPU load
LD3
uSD activity
LD4
Tally (either Main or Preview)
Digilent Arty-Z7-20
Available Examples
One FPGA example is available for the Arty-Z7 board:
  • Arty-Enc.Xil: NDI Encoder based on Zybo "Lite" design
The default uSD image uses the Zybo boot files, however the Arty boot files are included. To modify the uSD image to boot on the Arty, simply update the files in the FAT partition before booting the Arty board:
Ref
Function
Setting
JP4
Boot Mode
SD
JP5
Power
USB (when using USB power)
JP5
Power
REG (when using J18 with 7-15V power)
Connections
Ref
Function / Label
Connect to
J10
HDMI Rx
J11
HDMI Tx
J8
Ethernet
J14
PROG/UART
LEDs
LED
Function
LD0
Tally (Main)
LD1
Tally (Preview)
LD2
CPU load
LD3
uSD activity
Xilinx ZCU104
Available Examples
  • Dec: Decode example with 4 NDI Decode cores
  • Enc: Encode example with 4 NDI Encode cores
The default uSD image uses the Enc files, however files for all examples are included on the uSD card. To change the example design, simply update the files in the /boot directory and reboot:
Ref
Function
Setting
J85
POR_OVERRIDE
2-3 (default)
J12
SYSMON I2C addr
1-2 (default)
J13
SYSMON I2C addr
1-2 (default)
J20
PS_POR_B
1-2 (default)
J21
PS_SRST_B
1-2 (default)
J22
Reset Seq
open (default)
SW6 1
PS_MODE
On
SW6 2
PS_MODE
Off
SW6 3
PS_MODE
Off
SW6 4
PS_MODE
Off
Connections
Ref
Function / Label
Connect to
P7
HDMI Rx (bottom)
HDMI video source
J52
Power
Power supply
P12
Ethernet
Ethernet network
J164
JTAG/UART
LEDs
LED
Function
LED0
LED1
Tally (Main)
LED2
Tally (Preview)
LED3
CPU load
Xilinx Kria KV260
Available Examples
One FPGA example is available for the Kria KV260:
Board setup
The NDI example design requires the same board configuration as the Xilinx "Smart Camera" example, including the FSBL programmed into the on-module flash memory and the AR1335 camera module as provided in the Basic Accessory Packarrow-up-right connected to J7.
See the Getting Startedarrow-up-right instructions from Xilinx for full details.
There are no jumpers or switches to set on the KV260, and there are no user LEDs available to indicate tally.
