> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/using-ndi/using-ndi-with-software/use-obs-video-+-audio-on-zoom-with-macos.md).
# Use OBS video + audio on Zoom with macOS
MacOS System Audio not Captured via NDI Scan Converter
1. Install or update:
   * OBS Studio 30 or newer
   * Distro AV NDI plug‑in for OBS
   * NDI Tools 6.1.1 for Mac — be sure to tick “Virtual Input” during setup and allow its Camera and Microphone extensions when macOS asks.
2. In OBS open **Tools** then **NDI Output Settings**, enable **Main Output**, give it a name, and click OK.
3. Launch **NDI Virtual Input** (in Applications > NDI). From its menu‑bar icon choose the OBS feed. Restart the app if you just approved permissions.
4. Open Zoom (or Google Meet, Teams, etc.).
   * Pick **NDI Video** for camera.
   * Pick **NDI Audio** (or “NDI Virtual Input”) for microphone. If the virtual mic is missing, reinstall NDI Tools and reboot.
**Issue:**\
When using [**NDI Scan Converter**](/all/using-ndi/ndi-tools/ndi-tools-for-mac/scan-converter.md) by itself, the video signal is transmitted over NDI, but the audio is silent or only captures the system microphone. This is expected behavior.
**Solution:**\
Use an audio loopback tool to route system audio into the NDI stream:
* [Blackhole](https://existential.audio/blackhole/)
* [Loopback](https://rogueamoeba.com/loopback/)
* [Soundflower](https://github.com/mattingalls/Soundflower) (deprecated)
**After installation**:
1. Follow the tool’s instructions to route system output to a virtual input.
2. Launch [**NDI Scan Converter**](/all/using-ndi/ndi-tools/ndi-tools-for-mac/scan-converter.md).
3. Ensure audio is not muted in the Scan Converter menu.
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://docs.ndi.video/all/using-ndi/using-ndi-with-software/use-obs-video-+-audio-on-zoom-with-macos.md?ask=<question>&goal=<endgoal>
