Technical Requirements
The following technical requirements are specific to each NDI format, but if a device can support more than one format, it will be certified and tested under both types separately.
In addition to the following technical requirements, Interoperability Requirements must be followed.
NDI High Bandwidth
The specific criteria for NDI High Bandwidth certification are:
I Frame only for Keyframe
Less than 100ms latency
SpeedHQ codec
2160p
60, 50, 30, 25
1080p
60, 50, 30, 25
1080i
60, 50
720p
60, 50, 30, 25
576i
50
480p
30, 25
480i
60, 50
SHQ0-7
8bit, 10bit
4:2:0, 4:2:2, 4:2:2:4
YUV
NDI HX2
This certification is for products that support NDI HX2 but cannot pass the technical certification requirements of NDI HX3. Critically, they still pass the Interoperability requirements. These devices may have slower latency or keyframe or a larger GOP. The key criteria are:
150ms glass-to-glass latency
Keyframe response time under 80ms
Current SDK or previous SDK (6.0 currently, 5.6 previous as of this writing)
H.264 or H.265 encoding
2160p
60, 50, 30, 25
1080p
60, 50, 30, 25
720p
60, 50, 30, 25
480p
30, 25
H.264
8bit, 10bit
4:2:0, 4:2:0:4
YUV
H.265 HEVC
8bit, 10bit
4:2:0, 4:2:0:4
YUV
NDI HX3
This certification is for products supporting NDI HX3 that fit one of the following criteria:
Encoder
GOP setting set to 20
Video compression set to low latency
Latency
100ms Glass-to-glass Latency
Compression
Quality: no visible compression artifacts
Compression: constant bitrate (CBR)
2160p
60, 50, 30, 25
1080p
60, 50, 30, 25
720p
60, 50, 30, 25
480p
30, 25
H.264
8bit, 10bit
4:2:0, 4:2:0:4
YUV
H.265 HEVC
8bit, 10bit
4:2:0, 4:2:0:4
YUV
NDI 6 Optional Features
HDR
With NDI 6, HDR is now officially supported as a sender and receiver for NDI HX (HX2 and HX3 only) and NDI High Bandwidth. To qualify under either, the following must be met:
HDR optional toggle - not every receiver is HDR compatible, and NDI strives for forward and backward compatibility. HDR must be allowed to turn off at the end user's request
BT_2020 or BT_2100 primaries (as defined in the SDK for HDR)
10 and 12-bit video
NDI Bridge
With NDI 6, NDI Bridge functionalities can now be embedded into a device or application to connect across networks, even across the public Internet, easily. As this is a connection method rather than a quality metric, certification will depend on the ability to implement the following:
NDI Bridge optional toggle - Bridge must be enabled or disabled at the end user's request
Fields to enter IP, port, username, and password
Connection success or failure messaging
