> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-for-mac/video-monitor.md). Agents can also search and read this documentation through its [MCP server](https://docs.ndi.video/all/~gitbook/mcp).
# Video Monitor
Your Window to NDI Signals.
**NDI Studio Monitor** is a tool that allows you to effortlessly view video and audio signals transmitted over your network through an NDI stream.&#x20;
Studio Monitor is a valuable tool for anyone involved in video monitoring, digital signage, KVM control, recording, PTZ operation, or more.
## **Accessing NDI Studio Monitor**
[Install NDI Tools](https://docs.ndi.video/all/using-ndi/ndi-tools/installing-ndi-tools.md) and run NDI Studio Monitor from the [NDI launcher](https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-launcher.md) or your applications list.
## **Remote Control and Navigation**
The application launches as a pop-up window, providing an IP address or QR code for remote control from another device on the same network.
## **Viewing NDI Sources**
Click on the `NDI` button on the top menu bar to browse a list of devices broadcasting over NDI. Then, you can select any channel to view the video and audio in real-time.
If your desired source is not listed, ensure that the equipment is on the correct network and configured properly.
## Settings and Customization
Explore the `Settings` tab to customize your viewing experience:
* **Low Bandwidth:** Optimize viewing NDI sources in low bandwidth contexts.
* **Mute:** Mute audio from the selected NDI source.
* **Set Record Path:** Specify the location where recorded files will be saved.
* **Allow Receiver Advertising:** Makes Video Monitor available for monitoring when using Discovery Server.
{% hint style="success" %}
Initiate recordings by clicking the red button in the top right corner of the application.
* **PTZ Control:** Take advantage of NDI Video Monitor's capability to **remotely control** [**PTZ**](#user-content-fn-1)[^1] **cameras**. Select the NDI camera source under the `NDI` tab and access PTZ Control under `Settings`. Manipulate camera movement and store preset positions for quick recall.
* **Device Web Page:** Access the web page of certain NDI-enabled cameras and devices for configuration changes.
To open multiple instances of Video Monitor on Mac use the command `open -a "NDI Video Monitor.app" -n` on Terminal
[^1]: Pan-tilt-zoom (**PTZ**) cameras are built with mechanical parts that allow them to swivel left to right, tilt up and down, and zoom in and out of a scene.
GET https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-for-mac/video-monitor.md?ask=<question>&goal=<user_goal>
