Scan Converter
Share Your Desktop Seamlessly.
NDI Scan Converter is an application designed to effortlessly share your computer's desktop video and audio with any other device on your network through an NDI stream.
Whether you're conducting broadcasts and presentations, collaborating on projects, creating tutorials, or engaging in media playback, Screen Capture provides a valuable solution.
Accessing NDI Scan Converter
Install NDI Tools and run NDI Scan Converter from the NDI launcher or your applications list.
Sharing Your Screen
The tool will appear in your system tray with the NDI logo. Upon launch, your computer's desktop video and audio are viewable from any NDI-enabled device on your network.
Viewing on NDI-Enabled Devices
View the output of Screen Capture on another NDI-enabled device using an application like Video Monitor.
Right-click on the screen and select the device name and corresponding NDI stream.
Desktop or Application Selection:
On the
Filetop level menu, you can select which will be the source of your NDI stream. Select eitherDesktopto capture your entire desktop or choose a specific application window.
System Audio Input Configuration:
You can mute audio capture by clicking Mute Audio, which can be found on the Settings top-level menu.
Choose the desired system audio input for capturing sound along with your video in your MacOS Sound settings.
If you want to share your Mac screen or a single app window as a standard high-bandwidth NDI source, use Scan Converter. It can send a selected application window, carry audio, and make the stream available to other NDI-enabled devices.
