# Page Not Found
The URL `using-ndi/ndi-bridge/ndi-bridge-buffer` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [NDI Tools Launcher](https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-launcher.md)
- [NDI Encoding Support Matrix](https://docs.ndi.video/all/using-ndi/ndi-for-video/ndi-encoding-support-matrix.md)
- [Digital Video Basics](https://docs.ndi.video/all/using-ndi/ndi-for-video/digital-video-basics.md)
- [NDI for Video](https://docs.ndi.video/all/using-ndi/ndi-for-video.md)
- [NDI HX upgrades for cameras](https://docs.ndi.video/all/using-ndi/ndi-with-hardware/ndi-hx-upgrades-for-cameras.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
GET https://docs.ndi.video/all/using-ndi/ndi-tools/ndi-tools-launcher.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `build a script that syncs our docs to a CMS` lets GitBook tailor the answer to that use case.
### Option 2 — Browse the documentation index
Full index: https://docs.ndi.video/all/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.ndi.video/all/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/all/using-ndi/ndi-tools/ndi-tools-launcher.md`).
You may also use `Accept: text/markdown` header for content negotiation.
