For the complete documentation index, see llms.txt. This page is also available as Markdown.
Metadata Elements
<ndi_product> Element
Initial Implementation: Vizrt
Used by both NDI senders and receivers to indicate product details.
<ndi_product
    long_name="NDILib Receive Example."
    short_name="NDILib Receive"
    manufacturer="CoolCo, Inc."
    model_name="PBX-42Q"
    version="1.000.000"
    serial="ABCDEFG"
    session_name="My Midday Show" />
<ndi_product> Attributes
Attribute
Description
long_name
Full human readable product name
short_name
Abbreviated human readable product name
manufacturer
Product manufacturer
version
Product firmware version
model_name
Product model name
serial
Product serial number
session_name
Session name for TriCaster or similar products General product information for other devices
<ndi_capabilities> Element
Indicated product capabilities for both NDI senders and receivers. Most capabilities are sender specific (ptz and exposure control) but NDI receivers will often have a web_control URL.
<ndi_capabilities> Attributes
Attribute
Description
web_control="URL"
The URL to the local device webpage. If %IP% is present in the value, it will be replaced with the local IP of the NIC in which the NDI receiver is connected to.
ntk_ptz="true"
Signifies that this NDI sender is capable of processing PTZ commands sent from the NDI receiver. The NDI receiver will only assume the NDI sender can support PTZ commands if this attribute is received and set to the value “true”.
ntk_pan_tilt="true"
The NDI sender supports pan and tilt control.
ntk_zoom="true"
The NDI sender supports zoom control.
ntk_iris="true"
The NDI sender supports iris control.
ntk_white_balance="true"
The NDI sender supports white balance control.
ntk_exposure="true"
The NDI sender supports exposure control.
ntk_exposure_v2="true"
The NDI sender supports detailed control over exposure such as iris, gain, and shutter speed.
ntk_focus="true"
The NDI sender supports manual focus control.
ntk_autofocus="true"
The NDI sender supports setting auto focus.
ntk_preset_speed="true"
The NDI sender has preset speed support.
ntk_kvm="true"
The NDI sender supports KVM control.
<ndi_format> Element
Sent by an NDI receiver to indicate it's preferred or native format.
<ndi_format> Children
At least one of the following child elements is required.
Child
Description
<video_format>
Video format details
<audio_format>
Audio format details
<video_format> Attributes
Attribute
Description
xres
Horizontal resolution in pixels
yres
Vertical resolution in lines
frame_rate_n
Numerator portion of the frame rate
frame_rate_d
Denominator portion of the frame rate
aspect_ratio
The picture aspect ratio, 0 means square pixel
progressive
Indicates progressive format when "true" or interlaced format when "false"
<audio_format> Attributes
Attribute
Description
no_channels
The number of audio channels
sample_rate
The number of audio samples per second
<ndi_color_info> Element
Initial NDI Version: 6.0
The <ndi_color_info> element provides colorimitry details for the associated video frame.
<ndi_color_info> Attributes
Attribute
Description
primaries
Specifies the chromaticity coordinates of the color primaries of the video frame. One of: “bt_601”, “bt_709”, “bt_2020”, or “bt_2100”
transfer
Specifies the brightness transfer characteristic. One of: “bt_601”, “bt_709”, “bt_2020”, “bt_2100_hlg”, or “bt_2100_pq”
matrix
Specifies the matrix coefficients used in deriving luma and chroma from RGB or XYZ primaries. One of: “bt_601”, “bt_709”, “bt_2020”, or “bt_2100”
<ndi_metadata_group> Element
Initial NDI Version: 6.0 for video frame metadata, 6.1 for generic metadata frames
Properly formatted XML allows only one root element. If multiple metadata elements need to be attached to a single audio or video frame, they should be grouped together as child elements of an ndi_metadata_group root element.
<ndi_tracking_info> Element
Supported Protocols: FreeD, Trackmen
Initial NDI Version: 5.x
<ndi_tracking_info> Attributes
Attribute
Description
version
The <ndi_tracking_info> element must have a version attribute. The version attribute is defined as string with the regex format: [0-9]+.[0- 9]+.[0-9]+
<ndi_tracking_info> Children
Child
Description
<package>
<ndi_tracking_info> can contain zero or more <package> elements
<package> Element
The <package> element holds one single tracking package. This element contains no text.
or
<package> Attributes
Attribute
Description
type
The <package> element must have an attribute named type with a value of either binary or axis
protocol
The value of the attribute protocol is the name of the tracking protocol which is embedded in the XML description of <package>. This attribute is mandatory
<package> Children
Child
Description
<timestamp>
The <timestamp> element is optional
<data>
If the type of the is binary then exactly one <data> element is mandatory.
<axis>
If the type of the is axis then one or more <axis> elements must be present.
<timestamp> Element
When present, the element can provide some additional timestamp information different from the timestamp on the NDI video frame. This element contains no text and has no children.
<timestamp> Attributes
Attribute
Description
name
Is optional and defines the process step when the timestamp was taken. If name is not given, the timestamp will be marked as capture which means the time the video frame was recorded. If the name attribute is not capture, then the timestamp on the NDI video frame is taken as capture timestamp. Please see Appendix Timestamp names.
type
Is mandatory and has a fixed value of xs:dateTimeStamp. The timestamp value must follow the xs:dateTimeStamp format. Please see https://www.w3.org/TR/xmlschema11-2/#dateTimeStamp. A UTC timestamp is preferable.
<data> Element
The element contains the binary representation of the protocol. This element has no attributes and no children. The text value must be encoded in the xs:base64Binary format. Please see https://www.w3schools.com/xml/schema_dtypes_misc.asp
<axis> Element
The <axis> element contains data for one axis. This element contains no text and has no children.
<axis> Attributes
Attribute
Description
name
Identifies the axis. If the name is known by the Tracking Hub, the assignment to the rig axis can be done automatically. If not, the assignment must be done by the operator. Either way, a unique name must be given.
type
Identifies the format of the content of the <axis> element. The type attribute must be one of the following:
  • xs:integer
  • xs:float
  • xs:boolean
  • xs:double
  • xs:long
value
The value of the axis. The type must match the attribute type.
<ndi_video_codec> Element
Sent via NDIlib_recv_send_metadata() by the application which created the NDI receive instance.
This requests the NDI library use the specified decoding method for H.264 and H.265 NDI video streams. Note that the internal heuristics should generally be allowed to select the codec type in most circumstances.
Note this element can only be sent by an application to an NDI receiver instance, this element will never be received in a Metadata frame by an NDI sender or receiver instance.
<ndi_video_codec> Attributes
Attribute
Description
type
Video codec type One of: "hardware" or "software"
