> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/developing-with-ndi/ndi-metadata/metadata-and-xml.md).
# Metadata & XML
## NDI Metadata and XML
While NDI metadata is formatted as XML, there are some differences between XML used for NDI metadata frames and a more conventional stand-alone XML file. This section discusses how XML standards apply to NDI metadata frames.
## XML Prolog
NDI metadata frames should not contain an XML prolog. Each NDI Metadata frame can be assumed to have the following prolog, indicating XML version 1.0 compliance and UTF-8 encoding.
```xml
<?xml version="1.0" encoding="UTF-8"?>
## XML Syntax
NDI metadata frames should be "Well Formed" XML documents with correct syntax. Please check the following:
* [x] Metadata should have one and only one root element
* [x] XML elements must have a closing tag
* [x] XML tags are case sensitive
* [x] XML elements must be properly nested
* [x] XML attribute values must be quoted
## XML Root Element
As a "Well Formed" XML document, an NDI metadata frame can only have one root element. If there is a need to pass more than one XML element in an NDI metadata frame, the root element should be set to `<ndi_metadata_group>` and the required XML elements can be passed as children to this root element.
See the documentation for the `<ndi_metadata_group>` element, below, for example usage.
## XML Comments
XML comments are allowed but **discouraged** in NDI metadata frames.
## XML Namespaces
XML namespaces are **not supported** in NDI metadata frames.
## XML Element Names
With the exception of element names defined in this document, no XML element passed in a metadata frame to the NDI SDK should begin with the string `ndi` or `ntk` (or any permutation of capitalization,eg: `Ndi`).
GET https://docs.ndi.video/all/developing-with-ndi/ndi-metadata/metadata-and-xml.md?ask=<question>&goal=<user_goal>
