> For the complete documentation index, see [llms.txt](https://docs.ndi.video/all/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ndi.video/all/developing-with-ndi/ndi-metadata/kvm-messages.md).
# KVM Messages
> Initial Implementation: **NewTek**
> Location: **Sent via SDK API calls, received as Metadata frames**
## API calls
A variety of API calls can be used by an NDI receive instance to send KVM events to an NDI sender. These API calls are briefly listed below. For further details refer to the `Processing.NDI.KVM.h` include file provided with the SDK.
### Detecting KVM Support
Senders indicate support for KVM via the `<ndi_capabilities>` connection metadata element.
Receivers can test to see if the sender supports KVM using the API call:
* `NDIlib_recv_kvm_is_supported()`
### Mouse Button Support
The following API calls are used to send mouse button press and release events to the NDI sender:
* `NDIlib_recv_kvm_send_left_mouse_click()`
* `NDIlib_recv_kvm_send_middle_mouse_click()`
* `NDIlib_recv_kvm_send_right_mouse_click()`
* `NDIlib_recv_kvm_send_left_mouse_release()`
* `NDIlib_recv_kvm_send_middle_mouse_release()`
* `NDIlib_recv_kvm_send_right_mouse_release()`
### Mouse Scroll Wheel Support
The following API calls are used to send mouse scroll wheel events to the NDI sender:
* `NDIlib_recv_kvm_send_vertical_mouse_wheel()`
* `NDIlib_recv_kvm_send_horizontal_mouse_wheel()`
The scroll value is scaled such that one wheel click is equal to 120.
### Mouse Position Support
Mouse position updates are sent with the API call:
* `NDIlib_recv_kvm_send_mouse_position()`
Mouse coordinates are absolute with 0.0 representing the top and left side of the screen and 1.0 representing the bottom and right side of the screen.
### Clipboard Support
Text clipboard content can be sent with the API call:
* `NDIlib_recv_kvm_send_clipboard_contents()`
Clipboard data must be a null terminated text string.
### Touch Support
The following API calls are used to send touch events to the NDI sender:
* `NDIlib_recv_kvm_send_touch_positions()`
* `NDIlib_recv_kvm_send_touch_finish()`
The touch data is an array of positions, with each position defined such that 0.0 represents the top or left side of the screen and 1.0 represents the bottom or right side of the screen.
### Keyboard Support
The following API calls are used to send keyboard events to the NDI sender:
* `NDIlib_recv_kvm_send_keyboard_press()`
* `NDIlib_recv_kvm_send_keyboard_release()`
Key codes are defined in the file `Processing.NDI.KVM.keysymdef.h`.
## `<ndi_kvm>` Element
NDI KVM messages are received at the sender as a metadata element with a Base64 encoded binary structure sent as an attribute.
```xml
<ndi_kvm u="A7WeJj9e7Tg/AQ=="/>
<ndi_kvm d="eNrjZQCCktTiEgYABqUBzg=="/>
#### `<ndi_kvm>` Attributes
| Attribute | Description                                            |
| u         | Base64 encoded uncompressed NDI KVM Message struct     |
| d         | Base64 encoded zlibl compressed NDI KVM Message struct |
There must be exactly one `u` or `d` attribute present. It is an error for both attributes to be present in the same `<ndi_kvm>` element, or for neither attribute to be present.
The Base64 data should be decoded into binary. Uncompressed messages are then interpreted per the structure and enumeration definitions found in `Processing.NDI.KVM.h`. Compressed messages need to be additionally decompressed using zlib before being interpreted as a KVM message struct.
The example uncompressed message above represents a cursor position message:
```sh
$ echo A7WeJj9e7Tg/AQ== | base64 -d | hexdump -C
00000000  03 b5 9e 26 3f 5e ed 38  3f 01                    |...&?^.8?.|
0000000a
The example compressed message above represents a clipboard message with the contents "test":
```sh
$ echo eNrjZQCCktTiEgYABqUBzg== | base64 -d | zlib-flate -uncompress | hexdump -C
00000000  0d 00 00 00 00 74 65 73  74 00                    |.....test.|
0000000a
GET https://docs.ndi.video/all/developing-with-ndi/ndi-metadata/kvm-messages.md?ask=<question>&goal=<user_goal>
